ecu and prom question
Old Yesterday | 03:22 PM
notyal75's Avatar
son bought a 87 camaro originally a 2.8 , the previous owner put in a 90? 5.0 tpi with a maf 165 ecu with a hypertech stage 3 chip.
we may be having issues witht he ecu 5v divider circuit for the ect as when cold and the key on i get 1.75v with the car started after a minute or two the voltage goes up and reflects what it should read at the current temp.
i found the 2.8 ecu under the seat along with the ecu from the 90s? camaro. stickers gone but the prom is atny 5672 i assume this is a speed density ecu and prom.
1. could i make the ecu work with the maf as long as i reprogrammed the prom or is it hard wired for a map system.
2. if not where can i get a 165 ecu or what would be a replacement ecu.
Old Yesterday | 03:51 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ecu and prom question
The ATNY has vats and is for the 1227730 305 automatic
Old Yesterday | 03:52 PM
Engine: Lb9
Transmission: M20
Are you looking for a 1227165 ?
Old Yesterday | 04:08 PM
notyal75's Avatar
probably, im going to check the circuits this weekend but believe the 5v divider circuit is hosed due to the ect voltage readings
Old Yesterday | 10:43 PM
Engine: Lb9
Transmission: M20
I have used and refurbished cardone. But unfortunately they are all untested units .
Twin_Turbo
Oct 16, 2012 07:13 PM
Astro
Oct 1, 2002 06:22 PM
super83Z
Jun 9, 2002 04:01 PM
ski_dwn_it
Oct 5, 2001 02:19 PM
