305 to 350
Old Feb 12, 2002 | 01:27 AM
Cyclops's Avatar
305 to 350
I just jot a home computer so forgive me if I do anything wrong...Anyway I have a 87 camaro 305 tpi. Blew up the motor so I went to the junk yard and jot a L98 out of a 89 Pontac GTA. Bolted all my old stuff on it, accept the injectors and fuel reg. I used off the L98. Now my check eng light comes on. When i pull the code it says oxgen sensor failure. What do I do to fix it? Thanks
Old Feb 12, 2002 | 12:47 PM
kevinc's Avatar
Car: 1982 Z28
You also want to swap over the knock sensor from the 350, it's located in the passenger side block coolant drain hole. They're specific to engine size.
Check the wiring to your O2 sensor, sounds like it either didn't get connected or maybe the wire got burned by the exh system. That error means the ECM is seeing no voltage at all from the O2 sensor.
Old Feb 12, 2002 | 01:43 PM
Cyclops's Avatar
I changed the oxgen sensor twice both times it made a big differnce at first. After a day or two lose of power and my friend check engine light came back
Old Feb 12, 2002 | 06:54 PM
Cyclops's Avatar
I put the 22lb injctors with the 305 computer now I think that I am running rich or lean but I dont knnow witch one??
Old Feb 12, 2002 | 06:57 PM
Cyclops's Avatar
Changed knock sensor also .............no differnce??
Old Feb 13, 2002 | 02:38 PM
kevinc's Avatar
Car: 1982 Z28
Time to start reading ALDL data and seeing what's going on in the ECM.
Search on "moates" and you'll find a shareware DOS app that allows a PC to read, display, and save ALDL data. Add a cheap laptop and ~$60 cable from AKM Electronics and you're in business.
Old Feb 13, 2002 | 02:51 PM
Cyclops's Avatar
As I read all the posts about similar things I wonder if just changing the computer chip will help or do I have to change the whole computer??? If so what computers will be the same for 1987 camaro w/ac . I need to use all my accesories from 1987?>??????
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
