acronyms unexplained
Old Feb 12, 2002 | 05:49 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I was looking for some documentation the other day that would give a brief description of the headings for the tables and constants listed in a (.ecu) file and (.tdf) file. Things like "PE %change AF ratio vs rpm". I read it as power enrichment percent change air to fuel ratio vs rpm. How can the power enrichent mode have a percent change..........it is either on or off. If you know of a document explaining these things, please post where I can find it.
Thanks,
J
Old Feb 12, 2002 | 06:43 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
It means "Once you are in PE, this is the % of extra fuel it will add to the AF Ratio".
If you add 10% more fuel with this table, will will be reducing the AF Ratio from 14.7 (assuming you had your eprom properly tuned to 14.7 at 128/128) to 13.2-13.3:1. 15% would make it around 12.4-12.6:1, and 20% would be around 11.7-11.9:1
But you really need a WB O2 Sensor to verify what you're TRUE AF Ratio is when in PE.
polymer52
Nov 4, 2012 08:45 AM
pwdbychevy
Mar 5, 2004 10:56 PM
junkyarddog
Theoretical and Street Racing
Nov 16, 2002 12:59 PM
88SS6SPEED
Jul 24, 2000 05:39 PM
