None of these chips will program
Old Feb 12, 2002 | 08:32 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
I got a new batch of 2732A chips. They only remain blank. I recieved ten so I doubt their all bad.
Expected 00 when blank. Found FF
Expected "X#" when programed. Found FF
This is with the pocket programmer(Win_Prg.exe)
I have a single old 2732 chip that works, otherwise I am out of chips.
Please tell me this is something simple.
Old Feb 12, 2002 | 11:21 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: None of these chips will program
Look at what the programming voltage is that you're using, and see if one of the other 2732 setting has a higher programming voltage and try that.
Old Feb 13, 2002 | 08:38 AM
Aaron91RS's Avatar
Car: RS
I've tried different voltages. No luck.
Old Feb 13, 2002 | 10:40 AM
I8AStang's Avatar
burn
This is gonna sound stupid, and if you did this then that's fine, but never overlook the obvious. Are you sure you selected 2732a and not 2732 when you tried to burn the a's. I made this mistake one time (fried 2 chips, thought my burner was bad). I know this is obvious, but that would be the first thing I checked.
Old Feb 13, 2002 | 11:00 AM
Aaron91RS's Avatar
Car: RS
To select different voltages you select 2732A or 2732. I tried this.
If anyone has some used tbi chips and wants to sell them via paypal. I desperately need them.
Could it have anything to do with the program expecting 00 and seeing FF. Do I have to change what it interpets as blank and full?
Old Feb 16, 2002 | 10:57 PM
Chop_Top's Avatar
I had that happen and it was due to the wrong selection,
had to pick the 2732
I just bought a few 2732 chips here http://www.unicornelectronics.com/
Ordered monday, had them by friday.
Old Feb 17, 2002 | 12:43 AM
formula5's Avatar
I might have a couple
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
ULTM8Z
Oct 2, 2015 01:25 PM
