Pump Shot Question
Old Feb 16, 2002 | 01:21 PM
PIANOMAN's Avatar
Pump Shot Question
In Tunercat, pump shot table vs. tps, WHERE does the enrich-
ment actually take place in the 0% line? At startup? Some bins
that I've been comparing have 0 as a value, and some have
more. 350's run between 61 and 122, where some 454's have
0 (stock GM bins). I'm trying to solve a slight flooding problem
right after startup, and need to know if the low %tps pump shot
tables might need to be decreased.
Thanks for your help!!
Roger
Old Feb 16, 2002 | 05:13 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I *think* the 0% TPS is added all the time. That's my guess.
If you have a slight flooding problem after start-up, I would try raising the cranking AFR to lean it out.
Old Feb 17, 2002 | 01:11 PM
PIANOMAN's Avatar
I've already leaned the cranking afr's and the open loop tables,
and cold driving is very good. The problem only arises once
in a while, and only on a restart at about 40-50 deg.c. and
only if I put it in gear before the idle speed comes down.
I'm really only interested in knowing WHEN the 0%tps pump
shot is actually applied. Does anyone know this? BTW,
we're talking about a '7747 ecm. Mr. P? Glenn?
Orr89RocZ
Apr 25, 2016 08:28 AM
fasteddi
Sep 2, 2015 10:29 AM
Bryan F
Aug 18, 2015 02:28 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
