p.e. tables using nos
Old Feb 21, 2002 | 09:49 AM
RBMZ28's Avatar
Car: 87 IROC (low 12's)
Engine: 400 sbc .040 over
Transmission: 700r mod
still new at this and from what I have learned would work better
with a second chip burned, but which direction should I best go
in the p/e tables(6e)running nos?car is mainly a weekender.(very little highway driving.
Old Feb 22, 2002 | 07:35 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
More fuel (higher numbers) in the PE table(s). You could add a set amount of fuel in the PE vs. coolant temp table, then "fine-tune" the curve in the PE vs. RPM table.
Old Feb 22, 2002 | 10:31 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: p.e. tables using nos
The problem is you need to take the timing out, then add the fuel then the NOS, in that order.
Kinda hard to do.
If you want to at least not worry about the timing tooo much then get a J+S Electronics Knock Detector. That MIGHT take care of the timing end of things.
Old Feb 22, 2002 | 06:35 PM
RBMZ28's Avatar
thanks guys,should be burning by 2/26(chips finally arrive!!)
junior419
Apr 7, 2025 11:35 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
ULTM8Z
Sep 16, 2015 09:15 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
