Will my car run?
Subscribe
Feb 23, 2002 | 08:54 PM
this summer I might build a 383 or a 350 bored .060 over. put on alluminum heads, cam,headers about 9:5.1 compression and all the trick parts. I plan on starting programming eproms too, but untill I get the hang of it and get a good one would my car at least run? I konw I probably won't get max performance outta it, but would it run? thanks for the time
Reply 0
Feb 24, 2002 | 02:18 AM
Heavily depending on the cam, it should run. Most likely it will have problems idleing and have annoying driveability problems, but it should at least run with that MAF system. A SD system will be much less likely to deal with a drastic engine change (like going to a 383).
Hope that helps,
Matt
Reply 0
Subscribe
