'7747 tables
Old Feb 24, 2002 | 09:45 PM
Astro4X4's Avatar
'7747 tables
Am I wrong in assuming that the main fuel table #2 - VE adder is added to the table #1 VE at WOT??? And can someone tell me how exactly the main spark bias constant affects timing.
TIA
Old Feb 25, 2002 | 11:23 AM
Brent's Avatar
VE1 and 2 are added together all the time.
Main spark bias is subtracted from the total timing calc. If you are using Tunercat, the main spark table reflects this subtraction. No need to change this value.
There is a timing doc over at DIY-EFI it explains the 7747 spark control. Good reading.
Old Feb 25, 2002 | 11:12 PM
Astro4X4's Avatar
Thanx, and..... if the 2 VE tables are always added shouldn't I be trimming them both equally?? There must be a purpose for the second table that I haven't figured out yet.
Old Feb 27, 2002 | 12:05 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
My guess is they did that so they could control the VE tables using different methods. You can control an entire RPM range using the VE#2 table.
Azrael91966669
25
Jun 20, 2017 04:04 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
ULTM8Z
Sep 16, 2015 09:15 AM
