How do I find out the stock values ??
How do I get the data from my stock chip? Looking at the TC demo, i see a lot of prameters I am not farmilar with and a lot that I am farmilar with......How do i find out the stock prameters to use as a base line? I want to know this because I need some sort of starting point. EX..Injector puleses, BLM's, IAC, MAP sensor settings?
Car: Death Mobile
Engine: 666 c.i.
If you have a Programmer, then you can read the eprom and save the BIN. If not, then you can get a BIN from www.diy-efi.org for the particular ECM you are interested in.
Is there a particular BIN that you are looking for?
