fuel constants or maf tables?
Old Mar 6, 2002 | 08:20 PM
RBMZ28's Avatar
Car: 87 IROC (low 12's)
Engine: 400 sbc .040 over
Transmission: 700r mod
Thru search and general reading,I have read to start with fuel
constants, then read somemore and it reads work with the maf tables.
after gathering info vie scanner.To make a long story short,I currently have a t.p.i.s. chip,had 24lb. injectors.Switched to 32lb. injectors and car improved dramatically(same tpis chip doing nothing else.Using a scanner I have learned the blm to be 115/ 125 at idle,int at 108,both numbers improve at cruise(steady)but for learning purposes should I 1st change constant for fuel injector(i've also read the two does'nt necessary match)go scanning,extrapolate,and then go to maf tables?thanks in advance.:hail:
Old Mar 6, 2002 | 11:17 PM
drive it's Avatar
Yup, you've already got it lined out the way to go. Shoot for blms of 128 at all gps/rpm.
Old Mar 7, 2002 | 06:52 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: fuel constants or maf tables?
Yes, start with your universal changes first.
You want to make as small as changes as possible to net a given result, so first would be getting the fuel pressure right, and in that process get the injector size correct. Hopefully that will get the drivibility numbers about right, then the battery correction for minor idle stuff, and then you PE stuff. The you can futz around with AE, DFCO cold start drivibility if needed.
chazman
Aug 28, 2018 03:25 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
NBrehm
Aug 25, 2015 11:49 PM
chazman
Aug 22, 2015 02:01 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
