A few quick easy questions
Car: 1983 Z28
Engine: 6.6L 406
I have the tunercat program. I was looking at a few of the switches and I was wondering what they do. I just wanted to know before I turned them off.
N.O. fan request input
single/dual air valve Does this have to do with the canister purge?
power steering switch, Just leave this one off right?
Also I am running a T-56, what is a magnetic speed sensor?
thanks for any help
thanks for any help
Normally Open (connects circuit above a certain temp)
Other is normally closed
This is the AIR valve CAT port and Exh manifold port
Turn on if your have a PS switch that tells if pressure high.
Other is optical. T56 is magnetic and requires additional cal changes. Do a search on this.
HTH
John
HTH
John
