Very wierd IAC after cam swap...
Old Mar 14, 2002 | 01:50 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I just swapped my cam to a 196/206 @.050" .431/.451 roller. I noticed when driving (cold engine) the IAC is maxing out at 145. Also, when I'm cruising down the road at 45 mph (warm engine) the counts are way up at 80-90. They never used to go that high unless I was on the highway.
Anyone have any ideas?
Old Mar 14, 2002 | 04:39 PM
LS1thunder's Avatar
It sounds like you need to open up the throttle blades a little to give your cam a little more air. That will drop your IAC counts. You are looking for about 30 counts at idle once the ECM settles down to closed loop. After that adjustment, recheck your TPS to see if its between .5 - .6 volts. If its above .6 volts, readjust it.
Old Mar 15, 2002 | 04:28 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
I have 19 counts at idle. That's what it used to be before the cam swap. It just like to max out when I hit the gas. I was thinking I could set the throttle follower to a lower value(?).
Old Mar 16, 2002 | 09:29 AM
LS1thunder's Avatar
If you have 19 counts NOW at idle your good. If it is above 35 open up the butterflies and it will bring it down. I think it will lower it about 20 counts for every 1/2 turn you open it up. It's not instant, so open it up and drive it a little then check your counts. Then verify the TPS voltage.
Jorlain
Oct 8, 2015 01:57 AM
IROCtometal
Sep 9, 2015 10:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
masonta
Sep 1, 2015 06:40 PM
