How do I remove the chip from the holder??
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I am not sure if I am using the correct terminology but I have my hypertech chip and I want to remove the chip and compare it to my stock program. What is the recommended procedure?? De-solder? Pull??
Car: 1991 Firebird
Engine: 427 LSX
I can get some pics for you. It is a 4 point and it bolted in. It fits with the contours of the car unlike others I have seen. I would recommend it to anyone. I also had the bar behind the seats that runs hor. bolt in to retain functionality. I plan to add the six point bars later. I will also weld it. Email me and I will see what I can do about getting pics.
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Why not just use my software to read the BIN through the ALDL port? Or make a little adapter thingy out of a straight IDC header and stick it in the PP that way. No need to desolder. Isn't it just in a socket? Can you pop it loose that way? Maybe not, I don't know.
Or.. You get a small tip for your solder iron and a small flat blade screwdriver.. Unsolder 1 at a time and use the screwdriver to pull the pins out.. BE CAREFUL! You DO NOT want to pull the contacts out of the MEMCAL!
Car: 1991 Firebird
Engine: 427 LSX
How do I use his software to read the bin? I have the aldl link to a PC but didn't know this was possible. I tried prying but I don't think it will work.
Car: 87 T/A
Check the options menu, there should be one for dumpig the EPROM memory contents to a BIN file. Don't know if it'll work with a Hypertech chip, but I'd be interested to find out...
Car: 1991 Firebird
Engine: 427 LSX
Why do you believe it will not work? Could Hypertech put some sort of protection on the chip?? Thanks
Car: 87 T/A
Try it out, lemme know if it works OK. I know on some chips they won't even let you communicate at all, maybe they're afraid you'll discover their super-secret tuning techniques, I don't know.
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Originally posted by NufNuffZ28
Hi...Just wondering how you get Craig Moates software.
Chris
Chris
http://ice.prohosting.com/moates/gmecm/index.html
and download either of the ZIP files. I still haven't tried the Beta version (ECM850B.ZIP), but the non-Beta version (ecmv845.zip) was working great for me.
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
