idle surge and at times stall on start up
Old Mar 22, 2002 | 12:36 AM
drive it's Avatar
I just got done installing a SR and #30lb from 24lb inj. I've been using the arap on it with the 24lbers and siam runners and really had it dialed in-good starts idle etc. Now after some tuning I'm still having a hard time with it surging then even stalling at times after start up unless I give it 1/4 to 1/2 throttle. After about 30sec. then it's fine. I've tried IAC park, open loop f/a vs cool, etc. without success-has anyone else had this problem after larger inj. only? Or with a SR? I've already got the blms close to 128, and it does run fine everywhere else. Thanks for any ideas!!!!
Old Sep 29, 2003 | 05:29 PM
martyr's Avatar
Car: 88 Formula 350
Engine: 357
Transmission: 700r4 Edge 2900 Stall
Old post..but I have the same question.
Old Sep 29, 2003 | 06:59 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: idle surge and at times stall on start up
Sounds like it's too lean.
Also might look at the cold engine timing adder.
Old Sep 30, 2003 | 05:58 AM
thirdgencompta's Avatar
same prob
I have the same problem as you...I went from stock TPI to HSR with 24lb injectors...the only thing I changed in the bin was the flow rate to 26...do you have any suggestions what else I should change? my car doesn't idle when it's cold till it warms up for like 2 minutes...then it fluxuates between like 600 and 900 rpm's.
Old Sep 30, 2003 | 06:33 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: same prob
Injectors do vary in linearity.
Sounds like you need to add fuel in the MAF 1 Table.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
