Grumpy, TRAXION - Whats your opinion on adjustable fuel pressure regulators for TPI's
Old Mar 23, 2002 | 10:55 PM
LS1thunder's Avatar
What do you guys think about AFPR's for a 350 tpi? I'm running a stock FPR right now and I'm wondering what additional benefits I might see for upping the fuel pressure. I am planning on making one from a stock piece but I wanted to know if I would realize anything for the effort.
Oh, and yes I'm already tuning by burning my own chips. Also, gotta say "THANKS!!!" for all the information you guys post on here. Burning chips has been the biggest improvement I've done.:hail:
Old Mar 24, 2002 | 10:28 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I believe in the benefits of higher fuel pressure (to a point). But, unless you have a different fuel pump, any higher than 50 psi tends to shorten the life of the fuel pump.
I "optimized" my eprom for 48 psi.
Old Mar 24, 2002 | 12:15 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Grumpy, TRAXION - Whats your opinion on adjustable fuel pressure regulators for TPI's
It's another tuning aid.
The more tuneable your system is the better you can tune it.
With a fairly stock set up thou there isn't alot it will help with. I perfer to use them when the injectors have been changed, and make an injector appear SMALLER. Trying to make an injector flow more thur pressure is something I stay away from. It's easier on all the components to run a slightly larger injector, then trying to get by on too small of one.
Old Mar 24, 2002 | 09:58 PM
LS1thunder's Avatar
Thanks for the input. I guess I will give it a try. Just making sure it was worth the effort.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
