TBI injectors...how do they funtion?
Old Apr 6, 2002 | 09:46 PM
JPrevost's Avatar
Car: 91 Red Sled
I understand it's just like a speaker driver with a coil but I'm a little confused about it's actual mechanical features. For example...does the injector not care which way the wires are hooked up? I would think that under the holding the injectors open...the injectors would actually be closed, is this correct?
What about when you turned off the car...would the injector be stuck open or is there a spring inside the injectors that shuts them closed when no power going to the coils?
Sorry the complicated questions...just trying to better understand how the fuel is being delivered.
Old Apr 6, 2002 | 11:14 PM
32V_DOHC's Avatar
No coils typically only care when there is some other directional device in parallel. (eg diode or directional capacitor)
I would think that under the holding the injectors open...the injectors would actually be closed, is this correct? What about when you turned off the car...would the injector be stuck open or is there a spring inside the injectors that shuts them closed when no power going to the coils?
Injectors are apply power to open. The magnetic force created by the coil pulls the pintle(or other obstruction) out of the orifice to allow fuel flow. A spring seats the pintle when no power is applied.
HTH
John
Old Apr 7, 2002 | 01:07 AM
JPrevost's Avatar
Car: 91 Red Sled
That's what I though, thanks
Old Apr 7, 2002 | 12:47 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: TBI injectors...how do they funtion?
Think of it as a solenoid, like in a starter.
The plunger is the pintle, and then a physical stop for it's travel, and a spring to return it to it's *off* posistion.
NOW,
you can see why and where Peak and Hold injectors are needed.
As the weight of the pintle increases, you need more magnetic energy to move it. Energy, ie more amperage,
While most saturated injectors start to falter at anything under 1msec at idle, my Peak and Holds operate fine at .8 and less. This is with 55#ers on a lil v6. By flipping to SEFI, I can easily run even larger injectors <g>.
Now where did I put those 92#/hr. ones <G>
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
