Paging Craig Moates
Old Apr 12, 2002 | 10:42 AM
86Red4+3's Avatar
Paging Craig Moates
As I was looking through the ARAP code, I found something that doesn't match up with the 165FORM.DAT file included with the Ver 8.5 release. In the Mode 1 data stream item 15 used to point to MPH (LSB). In ARAP (and APYP, the manual version) this now points to $0003, Mode Word 3 which has the following booleans:
; Mode Word 3
; b0
; b1 VATS OK
; b2
; b3 error 51, chksum
; b4
; b5 VATS AREADY PASSED
; b6 error 36, MAF Burn off (B/O) PASSED
; b7 KNOCK ENBLED BY DIFF COOL
Item 14 still points to the MPH high byte* at $0066 and MPH is still stored as 2 bytes at $0066-$0067, but in Mode 1 diagnostics the low byte is evidently replaced by that mode word from '88 on.****************************
Old Apr 12, 2002 | 05:09 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Hmmm, maybe this is different than the datastream then compared to 86-87. I had assumed that the 86-87 was the same as 87-88, but there are differences I suppose. Hadn't gone into the 6E code to cross-check, but that's the right way to do it.
There's also a difference on some secondary MAT as well, did you see that?
I really should take a close look at the 6E code definition of the Mode-1 stream. I was going by other references...
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
Abubaca
Nov 5, 2016 12:22 PM
Dragonsys
Sep 25, 2015 03:51 PM
