Lean idle? Doesn't smell like it.
Modified 6E code in an 87 Vette. My BLM is 134 at idle, but the exhaust smells rich. I can't hear an exhaust leak. I think I've got all the vacuum leaks sealed up, but I don't think they'd make such a rich condition. I'm working on my WB to sniff the exhaust to find out what it really is, but until then, any ideas?
Car: An Ol Buick
Engine: Vsick
Re: Lean idle? Doesn't smell like it.
Or if you have a scope put that on it, and see if it's *lively*.
A dieing O2 can indicate lean so the ecm will add fuel.
134 aint too bad.
Hmmmm....
the $6E code seems to have this inherent lean idle problem. I see it often on the scanner myself. However, once you tip in on the throttle it'll snap back to 128/128...at least that's the way mine does it. I have seen 145 and higher @ 750 RPMs (Idle) but I have a feeling that this was done for a reason...namely emissions testing. I could be wrong but everyone I've ever talked to has the same phenomena with the $6E.
One of 2 cures for this problem...
a) make some battery voltage corrections
-OR
b) tweak the MAF scalar table 1 little by little until you get 128/128 on the scanner.
I don't pay it any mind anymore now that I see about 134-137 on the scanner...
HTH,
Brian P
89 IROC-Z 355
-OR
HTH,
Brian P
89 IROC-Z 355
I have been fighting the same problem except on a greater level.
Mine will slowely raise to 160,but soon as i hit the gas 128.
it also seems crusing and low steady rpm this will also happen
but not maxing out blm - just around 148.
as a quick test ive tried raising FP to 55lbs and still the same.
I have heard that the smallest of leaks after MAF can cause that to happen,I havnt ruled that one out yet for myself.
p.s.
I just got pocket programmer yesterday,ordering zif and flash
prom today.
p.s.
prom today.
eightsixseven
Dec 16, 2024 01:50 PM
maroe624
Apr 16, 2017 08:29 AM
