does hypertech chip make fans run all the time??
Old Apr 13, 2002 | 06:54 PM
JDIroc's Avatar
I have an 88' iroc 350tpi and with the hypertech chip the left fan runs all the time, ya its great the thing runs alot cooler but is it bad for the fan will it burn it out???
Old Apr 13, 2002 | 07:18 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
By any chance is your A/C or defroster on? Or are you sure you have the right T-stat or that it's not sticking partially closed.
On dual fan cars, turning the A/C (or defroster) on will cause the driver's side fan to come on until a certian MPH is hit (around 37 MPH).
Also, if the fan's "turn-off temperature" is lower than the temperature of the T-stat (e.g. the Hypertech is setup for 160* and you have a 195* T-stat) then the fan will never turn off since the "turn-off temp" of the eprom is less than the rated temp of the T-stat.
But you need to give more info. Like is the fan on IMMEDIATELY when you turn on the engine and remain on, or does they come on at a certain temp and then won't turn off.
Also, if you are getting certain "SES Codes", they will turn on the fans. You should get some scan code readings to see when the fans come on and what your Coolant temp is. You need the CTS reading which is what the ECM uses.
Lastly, nothing saying Hypertech didn't screw up the eprom and set the "switch" for the way fans operate incorrectly. People using the ARAP BIN have to re-set this switch to "N.O.".
On the question of whether it is okay to leave the fans running all the time, I personally don't think it's the best thing to do.
Old Apr 14, 2002 | 05:22 PM
JDIroc's Avatar
I don't think that the chip is the thermomaster chip, but yes i do have a 195 degree stat in there, so should i change it to the 160?? The drivers side fan comes on when the car goes on and never turns off. The passenger side fan comes on with the A/C and no i don't have the a/c on. I am not getting an engine light or any codes. The temp guage never passes 175
Old Apr 14, 2002 | 05:32 PM
Car: Death Mobile
Engine: 666 c.i.
Put the stock one back in to see if it "goes away". If so, then you know your problem.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NBrehm
Aug 25, 2015 11:49 PM
Exxon Limited
Aug 9, 2015 08:13 PM
