Need Help Please, Ground troubles
Old Apr 19, 2002 | 03:53 AM
Buisson 91TPIZ28&91B4C's Avatar
From: Louisville,KY Crawfordville (Tallahassee), FL
There has to be a bad ground in my int. somewhere. I Know its messing with the gauges [mainly the tach], and possibly a few other things. I know its not my cluster because I have two that work perfect in other 90-92's. I looked for a ground connection under the drivers dash and found no kind of gound connection or loose ground wire.
Does anybody have a factory ground connection under the drivers dash. where does it go to?
any help is all that thanks.
Old Apr 19, 2002 | 11:03 AM
Matt86Z's Avatar
Is the tach floating?
If so, check the engine ground strap. Mine did that after the (latest) engine swap, and that's exactly what it was.
Old Apr 19, 2002 | 03:00 PM
Tonyrodz's Avatar
Transmission: auto
There should be a ground strap on the pass side head--near the firewall--make sure it's nice and tight!
$750 L98
Feb 1, 2025 02:25 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
mrbird
Oct 20, 2015 03:43 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Lmancha96
Sep 25, 2015 08:11 PM
