V.a.t.s. Info
Old Apr 19, 2002 | 05:19 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
V.a.t.s. Info
Does anyone have any information about the vats system as far as wiring diagrams, pin in, pin out locations ,anything, anything at all , is the vats resistor value stored in the memcal?.... can't be the ecm chip.. Looking for years 89' and 92' . I am stuck switching over to tuned port . I can't get any current to the fuel pump relay. And no , i don't want to buy a $350 dollar chip to eliminate the vats, I'de rather hook up toggle switchs and start my car that way, hey...dale earnhardt didn't use a key to start his car...lol......Anyways i have a vats interrogator and i know what value the key is, just when i hook the diagnostic scanner up to the car it reads.....VATS :FAIL.....Anyone with any help on this one??...Two weeks and counting being stuck on this one ??
Old Apr 19, 2002 | 09:12 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
87 and earlier cars didn't have VATS. So if you get a chip for one it will not have VATS. I am doing this now because VATS is causing me lots of trouble and I can't figure out why, nor can my local mechanics. So I'm using the 87 chip until my custom chip arrives. Hope this helps.
Old Apr 22, 2002 | 12:50 AM
StuckThrottle's Avatar
Check out my earlier post...I have the pinout for the VATS module and the ECM if you you need them I could send them to you.
here is the old post
Old Apr 22, 2002 | 04:22 PM
polishdevil's Avatar
Car: 88 GTA
Talk to Zephyr, he will burn you a chip with the VATS disabled.
He works quick and well, my chip came today and i can't wait to get my zif socket to plug it up.
Dave
Fanatic1074
Oct 3, 2022 05:57 AM
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
