V.a.t.s.
Old Apr 19, 2002 | 09:14 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
V.a.t.s.
Anyone every had a problem with VATS interfering with how the car runs? Or starting? I had to wait 4 minutes or longer after shutting off my engine to get it to restart. After disabling VATS, the problem went away.
Old Apr 20, 2002 | 12:16 AM
MILT's Avatar
I am having a VATS problem right now. My question to you is this: what type of resistor(s) did you use? I have tried several times by linking various resistors and can never get the perfect resistance--i.e. off by 50 ohms or so--thus I am assuming that is why the damn bypass doesn't work.
Please give me an insight if you can.
MILT
Old Apr 20, 2002 | 08:54 PM
89Warbird's Avatar
Engine: 389 CID TPI
I disabled it by putting in a chip from a 1987 350 TPI car, they didn't have VATS in 87. So, problem solved. My custom chip will eliminate it altogether. I hope this helps.
jdukate
Apr 30, 2015 04:38 PM
TheHog91
Apr 22, 2012 09:28 AM
duece
Oct 30, 2011 09:35 AM
mehanso
Sep 20, 2011 07:52 PM
