92RSB4C hit the nail on the head!
Old Apr 23, 2002 | 05:06 PM
IROCBOY's Avatar
92RSB4C was absolutely correct, this strange wire is coming out of my fuse block and it causes my engine to run after the key is removed. Why would anyone put this wire in a car? does it do anything for performance or make starting it easy? it seems like a pretty mindless addition too me.
Old Apr 23, 2002 | 10:38 PM
92RSB4C's Avatar
I know that my old friend Johnny could hotwire his dad's 88 Z28 by connecting a few wires down there. That IGN connector has to have something to do with it.
Old Apr 24, 2002 | 01:04 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
You sure that wire wasnt from an electric fan? Sometimes the fan will act as a generator keeping the car running till the fans stop turning. Just checking, you dont want to overheat in the middle of rush hour traffic, if you are ever in it.
Old Apr 24, 2002 | 10:56 AM
IROCBOY's Avatar
Good call now that I think about it my fans don't work like they should anymore :hail:
Old Apr 24, 2002 | 07:33 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Ahh see. How did they used to work?
Old Apr 24, 2002 | 10:12 PM
92RSB4C's Avatar
Here's what happened with my car. I installed 2 lighted switches for the fans. I tapped into the ground source for the relay control and ran a wire to my console. Once the cars ignition was on, it would only act up if the primary fan was on and the lighted switch was lit up. It wouldn't do it w/ the 2nd fan was on. And, it wouldn't do it if the 1st fan lighted switch was not lit up. And, it would only act up if the power source was in the Ignition slot or the Battery slot. I found out that the Radio slot has no ill effects.
evilstuie
Jan 9, 2020 08:29 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Scamo-2.8
May 20, 2016 07:01 PM
evilstuie
Feb 28, 2016 03:33 PM
ydnar417
Sep 23, 2015 05:57 AM
