ignition wires
Old Apr 30, 2002 | 11:17 PM
jester111's Avatar
ignition wires
hi
if you were to short out an ignition wire with the engine running it would cause a rich condition and the computer would lean it out lower blms value correct or not?
If correct then bad wires should cause a rich condition right?
thanks
Old Apr 30, 2002 | 11:50 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
hi
thanks
What, What, What!
Are you talking about a plug wire?
Old Apr 30, 2002 | 11:54 PM
jester111's Avatar
simply yes yes yes
Old May 1, 2002 | 04:18 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
If you short a wire you will get an obvious miss and excessive oxygen in the exhaust which would probably lean the F/A mixture. If your question is would bad wires cause an overall rich running engine the answer is no. If the car is running well with no missing or erratic operation I would look elsewhere. A sluggish O2 sensor might be the culprit or some emission related problem. Make sure engine temp is coming up to proper area as this will cause the ECM to run a slightly richer mix. With modern wires and the much higher spark voltages from elec. ignition unless the wires are burnt or falling apart they should be your least suspect.
Old May 1, 2002 | 11:18 PM
jester111's Avatar
Thanks danno
I was having a serious brain f@rt!!!
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
