Neutral saftey switch/reverse lights
Old May 5, 2002 | 11:30 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
hey everybody.. i put a hurst promatic 2 and i'd like to make the reverse lights and **** work.. can anybody tell me what color goes to what for the wire harness.. thanks
Old May 5, 2002 | 07:51 PM
2vmodular's Avatar
the two very thick wires are to make sure the starter doesn't crank in any gear other than park or neutral.
dark blue wire is hot with the ignition key in the run position, light green runs to reverse lights and electrically connects to the dark blue wire when gear selector is in reverse.
there are two other small guage wires on the switch, one is a ground, the other is an input to the ecm. both wires connect electrically with the gear selector in park/neutral.
383cam
Sep 9, 2015 06:01 AM
TBRays98
Sep 6, 2015 05:05 PM
Ian Irvine
Sep 4, 2015 08:08 AM
Jetmeck
Sep 4, 2015 12:29 AM
luvofjah
Sep 3, 2015 07:08 PM
