comp. slows the car at a certain speed?
Old May 5, 2002 | 04:28 PM
91BlkRS's Avatar
i've heard of trucks that have comp. that slow down the truck after it hits a certain speed. do our camaros have that too and if so is there a way to get rid of it or make it so it won't slow the car down until a higher speed? BTW it did that to me while i was at 120 i think cuz my speedometer only goes to 110 and the stick went past it.
Old May 5, 2002 | 05:12 PM
Jza's Avatar
Jza
If you haven't messed with anything related to that on your car, then I doubt you went 120, since your car has a speed limiter that cuts the fuel when you hit 115.
Old May 6, 2002 | 01:49 PM
Rage13's Avatar
Car: 89 Firebird
Speed
I hit 130 with my old 91' 3.1 V6 (#'s on the speed-o stoped at 110)
Old May 7, 2002 | 05:51 PM
91BlkRS's Avatar
ok, maybe i hit 115, but that's not the point, i want to know how to make it so the car doesn't slow at all or doesn't slow down until a higher speed.
Old May 8, 2002 | 07:45 PM
NXS055's Avatar
there is a sensor that you can hook up to a switch and when the switch is on the car doesn't know how fast its going, so it just keeps climbing, but you get a code, and when the switch is off it acts normally, and the code goes away
there is as tech article on it...
Old Jun 17, 2002 | 10:49 AM
XxFreeBirdxX's Avatar
what sensor? what switch? where are they? how do you do it?
Old Jun 18, 2002 | 11:19 AM
BillD91RS's Avatar
Take a look at the tech articles. You will find an article that will tell you to put a toggle switch on the VSS input to the computer. When you toggle the switch the computer stops getting input from the Vehicle Speed Sensor. The computer does not know how fast you are going so it won't slow you down. The check engine light will come on (because of VSS failure) but the car should work just fine.
Azrael91966669
25
Jun 20, 2017 04:04 AM
B_Dubya
Aug 26, 2015 05:09 PM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
86Base
Aug 8, 2015 01:34 PM
