Possible electronic problem...no fire to the plugs
Old May 5, 2002 | 10:38 PM
TBI305Camaro's Avatar
ok ive replaced my igintion module, pickup coil, coil, and im still getting no spark...what kind of tests should i run on my wiring to try to figure outs whats up...i have a multimeter but still kinda dumb about how to use it
Old May 6, 2002 | 10:30 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Did you check to see if you have + charge on the fat pink or red wire in the coil? Also, check your rotor and you cap, just to make sure everything is fine.
David
Old May 7, 2002 | 12:26 PM
it was the freakin coil i didnt suspect it because its only 3 months old and its a hypertech...hyperjunk i guess...i decided to try the coil after finally figuring out how to use the multimeter and it was saying i had 11ish volts to the coil so...
Old May 7, 2002 | 01:02 PM
Davidgou's Avatar
So, is it working fine now???
pjsparts
Oct 29, 2025 06:39 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
64goatman
Sep 9, 2015 01:09 PM
