89 Z-28 electrical connections
Old May 7, 2002 | 10:41 AM
go10go4's Avatar
In looking under the hood I cannot tell if the wiring from the fuse panel to the engine compartment through the firewall is continuous, or if there is a giant connector at the firewall. It appears to be a giant connector unit. Is this the case? If so, has anyone ever seen electrical problems result from bad connections here, even though the connector has not been disturbed in any way?
Old May 8, 2002 | 02:11 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It's a bulkhead connector, it's just a big plug held there (to the other half inside the car) by a 10mm (or so) bolt.
If its's never been disturbed, there's no real reason to suspect a problem there, not to say it's impossible tho.
wigmobile
Feb 26, 2025 02:56 PM
codeysabatini
Nov 10, 2015 04:07 PM
gta892000
Sep 16, 2015 12:37 AM
corey8084
Brakes
Sep 15, 2015 08:14 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
