Where is the stock flasher '83 t/a
Old May 8, 2002 | 04:48 PM
lonewolf's Avatar
I am trying to replace my stock turn signal flasher with a heavy duty one (so i can use halogen bulbs) on my '83 t/a. I saw in here that it's in the convenience center and has blue/purple wires (that was for a camaro). Can anyone tell me where it should be on the trans am? I saw nothing that looked like what i had bought (small cylinder w/ two prongs) and nothing w/ just a blue/purple wire. Can anyone give a more precise location?
Old May 8, 2002 | 09:09 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Welcome to the boards...
I can't speak exactly for your 83 but, I've got an 84 camaro (both car are virtually wire alike for the most part) and, if yours is in the same spot as mine, prepare to be a contortionist.
once you you swing the "convenience panel" down, the flasher relay is up above it clipped to one of the dash supports. My original one was lround & light blue in color. Good luck getting to it
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
Genopsyde
Oct 7, 2015 08:35 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
