lights flicker when idle at stop light
Old Sep 15, 2000 | 08:14 AM
86blkIrocz's Avatar
All the lights (head lights/interior lights) flicker when I'm not moving. But as soon as I give it gas all the lights are steady on what can the problem be? I'm thinking that alt is bad what do you guys think??
David Higgins
1986 Black Iroc-Z
305 TPI
Edelbrock Cat-Back
K&N Air Filters
Old Sep 15, 2000 | 01:59 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Sounds like the voltage regulator or a grounding problem. Check the woven copper ground strap between the chassis (fire wall) & the pass side head & the strap between the battery neg. terminal & the chassis.
Tim
Old Sep 17, 2000 | 09:11 PM
IROC-ZTWENTYGR8
Guest
Posts: n/a
Do u have underdrive pulleys??
Old Sep 18, 2000 | 07:10 AM
86blkIrocz's Avatar
I hope I dont' sound stupid but what is an under drive pully?
David Higgins
1986 Black Iroc-Z
305 TPI
Edelbrock Cat-Back
K&N Air Filters
Old Sep 18, 2000 | 10:43 AM
tesla042's Avatar
An underdrive pulley is a replacement crank pulley (and sometimes a new alternator pulley).. By putting a smaller pulley on the crank to drive the belts, you can take some load off the engine... Freeing up some extra HP..
On the other hand, your alternator, power steering, a/c, water pump, and whatnot now all spin slower. This really doesn't matter if you're moving, BUT it could cause a problem if you idle for a long time, in that there's a lot of electricity drain, but not much power being made...
Many people have no trouble with it tho... Try just revving your engine if you're at a light for a long time... should help keep a charge.
91 T/A 305
STB, Airfoil, Hooker cat-back, pseudo-cold air to K&N, Accel coil, !cat, !smog pump.
300 lb*ft of rice churning power.
1992CamaroGirl
Dec 25, 2017 08:45 PM
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
zeitghaist
Aug 18, 2015 07:33 AM
Omega
Aug 10, 2015 12:46 PM
