question about brake light/ tail light
Old Sep 17, 2000 | 10:24 PM
matthew's Avatar
is the brake light and the tail light the same bulb? if it is, then how come my tail lights are working, but one of my brake lights isn't.
Old Sep 18, 2000 | 12:36 AM
Topgun's Avatar
as far as i know, they are the same bulb. some cars have septrate bulbs. If it is the sam bulb, then why it is doing that is because the brake light part of it requires a brighter light.. Have you ever had a head light go out and have the brights work? and it's the same bulb? Same concept. Just replace the bulb and it shoud work fine
EMAIL: CTopgun5@aol.com
_______
84' Z28
New 350 Ci 4 Bolt Main with all L69/HO Parts
4 BBl Carb
160º Thermostat
K&N High Flow Filter
700R4 Trans
15X7 Standard Z28 Wheels, With 215/65R15 BF Goodrich Comp T/A HR4 Tires
Charcol in Color
no T-tops, but wish
New Head unit, JVC KD-SX750
New Kenwood 3-Way 6X9's
New Pioneer Sub
New Jensen 4-Channel Amp
As FiremanZ28 says "Friends don't let Friends Drive Mustangs"
Pic of my Z28, thanks to ZZ4 and his web page: Http://www.geocities.com/ukzz4iroc/z28camaro.jpg
Old Sep 19, 2000 | 10:59 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
There are two separate filaments in the same bulb. If you look on the bottom of a 2057 bulb, there are two contacts - one for the dim (tail light) filament & one for the bright (brake light) filament. The common terminal for both filaments is the brass base of the bulb.
Here are some current draw figures I measured @ 14.2 volts for a few common bulbs:
Filament Current Draw (Amps)
Lamp Bright / Dim
1157 2.22 / 0.62
2057 2.18 / 0.49
2357 2.26 / 0.61
1034 1.96 / 0.60
Tim
Frozer!!!
Jan 19, 2024 04:55 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
