Tach question
Old Sep 17, 2000 | 07:31 PM
Matt86Z's Avatar
Tach question
My tach's nuts.
First of all, I swapped out the engine fot an old LG4 outta my '83 Pontiac wagon. None of the guages worked 'cept the speedo. That was fine, no sending units on the heads for temp, etc, etc. Good enough.
So the thing is, the tach deosn't work. I swapped out the old cap and rotor off the Z, just in case. No-joy. Funny thing is, the tach will read above about 4700, but then engine's DEFINATELY not turning that high. Any ideas...??
Matt86Z
~Check out my Thirdgen~
...This Ain't No Speedway!...
Old Sep 18, 2000 | 08:16 PM
Matt86Z's Avatar
Come on, somebody has to have an idea.
Old Sep 19, 2000 | 11:34 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The tach wire is white & goes from the coil to the tach filter (if your car has one) mounted to the fire wall, behind the distributor. The tach filter has a wire that goes into the harness to the firewall connector on the driver side.
Tim
Armored91Camaro
Aug 25, 2015 12:01 PM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
