Dual Electric Fan problem!!!
Old May 16, 2002 | 11:18 PM
MdFormula350's Avatar
Dual Electric Fan problem!!! Please HELP!!
i have a 1991 firebird formula 350 tpi all stock, anyway when i turn the key before i start the car the passengers fan comes on an stays on what causes this i need some help??
also i noticed that when i turn my a/c on that the drivers fan does not come on, would this have to do about my a/c needing a charge??
Old May 19, 2002 | 03:46 PM
some one, anyone??
Old May 19, 2002 | 06:20 PM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
Passengers side fan is run by a temp sensor between the # 6 and 8 cylinders. There may also be a relay on the drivers side firewall. Mine was the temp sensor.
Yes, if your A/C needs to be charged, the high pressure switch won't trip activating the driver's side fan.
Good Luck!
Old May 19, 2002 | 09:01 PM
thanks alot man, i looked at my temp sensor and for some reason its toated/burnt and all messed, so i am putting on another soon.
RazorN8
Jan 7, 2022 11:44 AM
krisner89
Oct 10, 2015 06:03 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
