ATTN: Tim Burgess
Old Sep 21, 2000 | 07:29 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
ATTN: Tim Burgess
this is re: my TCC lockup switch. ok i followed the blk/wht wire as far as i could and couldnt see if it was grounded. so i just spliced into the F wire (tan/blk) i think and attached it to a ground area....by the door jam. NOTHIN!!!!! what do i do. i remember when i attached a switch between the F and A terminals the little light came on. but when i pushed the brake the light turned off and once i released it, it came back on...but it didnt do anything to my TC. does it have anything to do with the fact that i had my tranny rebuilt and the put a new TC in it?? i dont know if it is a lockup TC. thanks in advance...rick
Old Sep 21, 2000 | 07:54 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
What gear were you in? The TC will only lock up in second, third or overdrive. The light should light whenever you throw the switch (regardless of gear), but it is misleading because it only shows when the lockup circuit is closed. It is not an indication of actual lockup.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
12.57 @ 111 mph.
12.04 @ 114 mph (50-hp nitrous).
http://www.ozemail.com/au/jca69/mods/williesz/willie.html
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
[This message has been edited by Willie (edited September 21, 2000).]
Old Sep 21, 2000 | 08:06 PM
Car: 90 Camaro RS
Engine: 305 TBI
i went through all the gears. i got up to like 50 and it never felt locked.
Old Sep 21, 2000 | 09:29 PM
Willie's Avatar
Try this: Find a steady cruising speed in second gear. The ECM will not lock the converter in this gear. Then throw the switch. If the converter locks, you will definitely know it. It will feel like a relatively hard shift and your rpm's will drop significantly. If this doesn't work, the converter is not locking up.
Willie
Old Sep 21, 2000 | 10:09 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Check the plug at the transmission. If it is seated properly, verify continutiy through the tan / blk wire up to the ALDL connector, and check for ignition power at the purple wire.
Tim
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
timonator
Sep 17, 2015 06:57 PM
SG91camaro
Sep 5, 2015 10:27 PM
TheExaminer
Aug 19, 2015 10:07 PM
Willie
Jan 18, 2001 06:03 PM
