Rear lock
Rear lock
How can I get in my rear hatch? The lock is broken(hammer)wireing is in shambles! Hatch has the pwr option and batt. was disconnected when it locked, so it's still raised some. Tried a screw driver from inside(played w/the locking motor)w/no luck.
Any ideas how to open it?
Thanks!!
Thanks!!
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
From what I remember there is a way to turn something and make the sliding part move up and down. I had the problem on my 87 where it would come up but not down. Can you get a hot wire over to the solenoid you should be able to release the latch that way.
There's no way I can get a wire to the solenoid, the cover is still there. I think I might have to break the cover off(don't want to)and unbolt the motor. Just seems like the hard way to do it. How about if I try to stick a pry bar under the hatch? If I don't break the tail lights, think it'll work?
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
how difficult would it be to take a battery and reconnect?
i've had to do this several times to mine while traveling across country towing it.
Duffster (age 31)
BEAT DOWN HARD 88' Camaro SC,
1978 Caprice Classic motor havin'(WITH NO COMPUTER),84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 (1),
245/60-16 Bridgestone CompTA's(on rear),
235/60-16 Pirelli P600 w/a curb check or 3(1),
REAR HATCH MASTER OF ALL!!!
Duffster_Camaro@HOTMAIL.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, also part of the non-existent Iowa crew.
Duffster (age 31)
AND THE TIRES:
1992 Trans Am
May 10, 2023 07:19 PM
I'llrocya
Feb 2, 2016 11:43 PM
Dialed_In
Aug 20, 2015 01:45 PM
