so how does traction control work?
Old Oct 6, 2000 | 07:22 PM
dwl's Avatar
dwl
i'm trying to think what 4th gen cars have that 3rd gens don't that makes traction control possible.. does it require a posi rear end?
Is it just some kind of "slip" sensor that cuts throttle?
I don't suppose there is any reasonable way to put traction control on a car that didn't come with it from the factory.
dwl 1991 RS
Old Oct 7, 2000 | 12:09 AM
N3ZNF's Avatar
Car: 89' Chevy IROC
Engine: L98 350
Hi,
I'm not sure, but I beleive it has something to do with the car using the anti lock brakes independantly to control better. Im probably completely off but I think that makes sense from something I read a while ago.
HTH
Martin
Old Oct 7, 2000 | 05:35 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
It basicly applies the brakes to the wheels that slip, so the wheels that grip can catch up. i.e. if you have a FWD car and the R/F wheel is on ice and spinning, it will gently apply the brakes to slow it down, and so that power is transfered to the L/F. If both are spinning, it will slow both wheels down. Traction control is an "add on" to ABS, it isn't seperate. Each wheel's brake can be independantly applied and released.
If you live in Southeastern US, check us out!
South East Thirdgen
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
Old Oct 7, 2000 | 10:22 PM
bigdaddy's Avatar
The forth gen uses timing retard more than anything else. it also will kick back on your throttle, totally computer controlled. It would be too expensive to do an add on
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
The_Phoenix
Feb 4, 2016 07:10 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
