Power Locks
Old Oct 7, 2000 | 09:26 PM
CanadianCamaro's Avatar
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Transmission: T-5 5-Speed Manual
Power Locks
The powerlock on the passenger side of my car does not work, it's been like this since '90 or so. Ive thought that i might be the relay but I don't know where it would be. Could it be one of the two behind the driver's side kick panel? I have power windows & mirrors too so could these relays be for them?
TIA, Don
Old Oct 8, 2000 | 10:01 AM
bigdaddy's Avatar
TIA, Don
I would try the thermal limiter fuses in the fuse box. It is the silver looking retangeluar boxes next to the fuses. You should have two of these. Try rotating them in each others slots and see if it helps.
Old Oct 9, 2000 | 08:12 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
There is only one "thermal breaker" for the lock circuit - it also powers the electric seat, if so equipped, so if one lock solenoid is working, the breaker should be OK. The relays are in the location you described. Operate the locks & listen for the clicking to help locate them exactly. A common electric lock problem is lack of lubrication. If the lock lever is difficult to move manually, then pull the door panel & spray some lube on the mechanism near the door latch that the lock actuator rod connects to.
Tim
Old Sep 13, 2004 | 08:24 PM
Maverick_82's Avatar
Car: '82 trans am (w/ t-top)
Engine: 5.0L 305 H
Transmission: automatic
I have a similar problem. If i push the power lock button it makes the noise like its locking and the locks jolt, but they dont lock! why?
Old Sep 13, 2004 | 11:05 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
mine didnt work so i took apart the door pannel and i found some wires that insulation had rubbed off so they were grounding out on the door pannel. taped them up and they work....well.....they dont because the actuators suck....it takes like 4 puses to get them to lock/unlock
Old Sep 14, 2004 | 03:08 AM
Morley's Avatar
Because the lock mechanics are dirty.
BRoss99
Aug 10, 2025 05:08 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
mantaguy
Sep 1, 2015 08:39 PM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
