My RPM gauge is a little sticky
Old Oct 14, 2000 | 12:24 PM
chevystud's Avatar
How do I make it...smoooooooth???
91RS, 305, 5-speed, black with pearl white racing stripes. Not that it matters, but K&N airfilter and flowmaster exhaust
Old Oct 14, 2000 | 02:17 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
you can start by calling it a tachometer, then go check all of the connections under the hood.
Its the green wire usually on the HEI.
My friend had a similar problem on his IROC and after his tune up the motor ran smoother and the tach operated like it was supposed to
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
Old Oct 16, 2000 | 06:18 AM
Chuck Everly's Avatar
Moving to the "Electronics Forum". You may have better luck getting your answer there.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Jk_Under
Sep 8, 2015 08:13 AM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
