Speedo & Oil Press. gone wacky
Old Oct 15, 2000 | 09:58 PM
Brian87L98's Avatar
Thanks alot guys!, problem solved...I took out the guage cluster and cleaned everything, the oil pressure is still screwy but the speedo works....Hell what can ya expect from a car with 181,000miles and is still pretty much perfect in every way, once again thanks alot!
Brian
[This message has been edited by Brian87L98 (edited October 16, 2000).]
Old Oct 16, 2000 | 01:13 AM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
sounds like you've got 2 problems.
loose or bad cable for speedo, and loose or bad connection for oil pressure.
literally check from the tranny to the gauge cluster for the speedo cable.
likewise from the oil pressure sensor to the cluster again on the pressure indication.
Duffster (age 31)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),Torker II intake, Holley 80457,600cfm w/vacuum secondaries,84' 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
Duffster_Camaro@HOTMAIL.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
Old Oct 16, 2000 | 09:03 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Your '91 does not have a speedo cable. The speedometer is electronic & is driven from the ECM speedometer output (4000 pulses per mile). It sounds like you have an intermittant open ground to the cluster or on the cluster flexible circuit card. Pin 2 of connector C2 is a black / white wire & grounds the oil pressure gauge, the speedometer, the fuel level gauge, and some if the cluster illumination bulbs.
Tim
GTAman
Jul 3, 2024 07:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
CatmanFS
Sep 19, 2015 09:00 AM
TrevinE
Sep 14, 2015 03:20 PM
