Shorted out my guages?!?!?!? :(
Old Oct 15, 2000 | 11:05 PM
IrocManiac's Avatar
I had unhooked the radar detector that was wired in by the previous owner. Well I took it off then was fixing to tape up the wires with electrical tape and they touched. Now my guages don't work. I checked my fuses and they were all good. Dashlights, Headlights and brake lights stereo all that works just not my guages. Anyone with ideas PLEASE HELP!!!!!!!
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Oct 16, 2000 | 01:11 AM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
did you knock the lead power wire to the fuse panel off?
high up in the kick panel area is the block you should look to for a loose/dangling wire.
Best of luck!
Duffster (age 31)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),Torker II intake, Holley 80457,600cfm w/vacuum secondaries,84' 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
Duffster_Camaro@HOTMAIL.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
Old Oct 16, 2000 | 08:48 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Are you sure that the 10 amp "gages" fuse tests good? If it does test OK, does the car run? The gauges fuse is fed from the same ignition switch feed that the ECM ignition power is fed from, so if the car runs, the feed from the ignition switch to the gauges fuse should be OK.
Tim
Old Oct 16, 2000 | 11:09 PM
IrocManiac's Avatar
It does run just think i shorted out the dash loom or something.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
sheachopper
Jul 31, 2019 11:27 AM
tmellott89
Oct 14, 2015 02:06 PM
