How can I wire my fan to be on with ignition on?
Old Oct 17, 2000 | 11:42 AM
gsmann's Avatar
I have a 1986 TransAm and I need my single fan to be on with the car on. Where can I find an accessory wire to hook up to the positive to the fan. Or is there a certain Relay I could purchase? Any help would be appreciated. Thanks
Old Oct 17, 2000 | 04:34 PM
TexasLT1's Avatar
Car: '92 RS
There is a simple solution for that. Find the fan relay and find the wire that actully turns the fan on, I think it is green/white. Cut it and splice a longer piece onto it and tie it into one of the many grounding screws. Anytime the key is on, the fan is on. The only reason I did this was because I was doing some other electrical work anyway, you probably wont want to start cutting wires, but it is a cheap and easy way
Old Oct 19, 2000 | 03:12 PM
Get Blown ?'s Avatar
On your driverside fire wall there should be a black oval like box, hooked to that box is a green w/ white stripe wire. Just splice into it and ground it out to run full time or add an on/off switch between the grounding wire to control it manually.
1989 Camaro RS LO3 WCT5 "The Hose Queen" 0-60' 2.34 1/4 15.8@87mph
http://350.StreetRacing.org
ICQ: 61342629 AOL IM: BlackSunshineZ28
Old Oct 20, 2000 | 12:14 AM
theformula's Avatar
Just wondering, but why do you want your fan constantly on? You'll burn out your fans and inhibit horsepower.
'92 Formula
305 TPI
Mods: SLP catback,SLP air foil,ported plenum,Crane AFPR (49psi),MSD6AL,homemade cold air,K&Ns,3:73s,JET fan switch...SLP 1 5/8ths are coming...oh yes
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
