MSD Harness
Old Sep 24, 2000 | 01:02 PM
Sharpcorner's Avatar
MSD Harness
I have a msd 6 just waiting to be installed on my formula. Is the wireing harness worth the money, or should I just hook it up?
Old Sep 24, 2000 | 03:54 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If you are good with a soldering iron, and don't mind cutting the connectors off of the harness, then you don't need the MSD GM harness adaptor. The harness MSD GM adaptor also would make changing back to the stock setup very easy.
Tim
Old Sep 26, 2000 | 12:33 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Get the Harness 2 minute installation guarenteed.
Old Oct 7, 2000 | 11:07 PM
Jza's Avatar
Jza
I second that.. You're already gonna spend too long just trying to find a place to put it. The harness is definitely worth it.
Old Oct 11, 2000 | 04:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Jza's right... took me a month to figure out a spot I liked for the thing, 5 minutes to wire the power & ground, and 30 seconds to use MSD's plug-in harness.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 19, 2000 | 11:43 PM
spitfire350's Avatar
what do yall think about your MSD's i am seriously thinking about getting one. what benefits will it have on a pretty much stock, Q-Jet, 350? and anybody have that MSD unit that lets you advance and retard your timing from inside the car. and if i could get the install process for the ignition it would be great. Thanks for all the help.
keep the stang's far behind u and the cops even farther
Old Oct 20, 2000 | 08:50 AM
There are a number of posts on MSD related topics - search for "MSD" in the electronics section. There's one pose titled "MSD 6AL ?'s" that shows a picture of an install. An MSD-6AL has a rev limiter built in to it - a necessity - & runs about $160 from Summit, the last time I looked. The adjustable timing module gives you 15 degrees of timing adjustment latitude from inside the car - the module was about $95 from Summit, the last time I looked.
Tim
Hotrodboba400
Dec 10, 2019 07:07 PM
sreZ28
Oct 22, 2015 08:21 AM
86CamaroDan
Sep 29, 2015 10:08 PM
crystal383
Interior Parts Wanted
Sep 22, 2015 01:20 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
