DC motor internals
Old Oct 20, 2000 | 07:29 PM
johns84bird's Avatar
Car: Pontiac Grand Prix GTP
Engine: 3.8L V6 SuperCharged
DC motor internals
Yes, this is another firebird headlight question, but I have done a lot of checking and trouble shooting. OK, here it is: I checked all of the wiring in the car with a multimeter, using a wiring diagram from a repair shop. The good news is it is all OK. The relays are also good, just bought new ones. There are no physical obstructions, but the driverside motor still doesn't work, so I took it apart. One of the brushes of the motor was very worn and broken off of the spring that holds it to the shaft. Also, of the two contacts (the ones that click between positions) doesn't click the way it should or even move away from one position. Is there anywhere I can get the internal parts besides a junkyard, and I dont have 180 bucks to buy a whole new motor. I am going to a couple junkyards tomorrow, so I would like to know if all headlight motors have these internal parts, even though there is more than design. Thanks,
John
84 Firebird with Trans am ground effects- 350 4bbl GM crate motor (LM1), T-Tops, automatic, K&N filter, 180* thermostat, ram-air hood scoop, flowmaster muffler, Accel cap & rotor, MSD Super Conductor Wires. Coming soon: new interior (grey), rear end work, subframe connectors, polyurethane bushings
hydrolic144
Sep 8, 2015 06:55 PM
gixxer92
Sep 1, 2015 04:32 PM
greenyone
Aug 29, 2015 11:08 AM
TheExaminer
Aug 25, 2015 07:34 PM
