Timing without disconnecting EST?
Old Oct 20, 2000 | 02:37 PM
JETHROIROC's Avatar
Anyone know what the timing should be on a '90 IROC with the 350 TPI at idle when warm WITHOUT disconnecting the EST? I just want to see if the ignition module is operating properly after I rebuild the distributor. Thanks guys.
Old Oct 21, 2000 | 10:13 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Do you mean without disconnecting the bypass wire? If so, it usually runs in the 20's.
Tim
Old Oct 21, 2000 | 11:01 AM
JETHROIROC's Avatar
Thanks, Tim. Yeah, I just wanted to check and see if my advance system was working OK. The base timing looks good but I think it's at about 30BTDC with the EST bypass connected. I plan on rebuilding that distributor this week so we'll se if that helps.
bamaboy0323
Sep 3, 2015 06:07 AM
1992Vortec
Aug 31, 2015 08:05 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
