Power side mirror ???
Old Oct 24, 2000 | 08:50 PM
Tony86TA's Avatar
The power mirror on my 88 GTA just quit going up and down. It still goes side to side though. Can these be repaired, or just replaced? Thanks
Old Oct 25, 2000 | 07:57 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If one side works & the other does not, then it's probably the motor behind the mirror, or the wiring between the switch & the motor. If both sides lost that functionality, then the switch is probably defective.
Tim
Old Oct 25, 2000 | 07:58 PM
Tony86TA's Avatar
I assume that in order to replace the motor, the mirror assembly has to come of the door?
Old Oct 29, 2000 | 04:11 PM
Tonyrodz's Avatar
Transmission: auto
Not really. Just pull off the glass mirror(carefully)There's 2 tabs-top and bottom-
There's some screws behind there just take them off and unplug the harness(inside door)should come right out.
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
stalkier
Aug 13, 2015 12:59 PM
89FormulaMan
Aug 10, 2015 10:01 PM
