A4 wiring question
Old Oct 30, 2000 | 05:11 PM
IRACE87's Avatar
Car: 1987 IROC-Z
Engine: 383 HSR, AFR 190
A4 wiring question
On the switch assembly connected to the shifter what is the purpose of the PARK NEUTRAL SWITCH with blk/wht and orn/blk wires. I know there is a neutral start and a back/up switche incorporated with it.I think those wires are connected to the ECM ??????
1987 IROC w/T56 and a 383 TPI in the works
Old Oct 31, 2000 | 03:23 PM
IRACE87's Avatar
Car: 1987 IROC-Z
Nobody knows
Old Nov 1, 2000 | 07:08 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The black / white wire connects to ground, and the orange / black wire goes to the ECM to indicate park or neutral. The wire to the ECM is grounded when the gear selector is in P or N, and is open circuit in any other position.
Tim
Old Nov 1, 2000 | 06:16 PM
IRACE87's Avatar
Car: 1987 IROC-Z
Thanks Tim,but what is the purpose of it,I need to know this to complete my T56 swap,do I close the circuit or live it open since I won't be using this switch any more.
Old Nov 3, 2000 | 10:09 AM
I'm not sure of all of the parameters that the input controls in the ECM algorithm. One of them is idle speed (higher in P & N). If you get a PROM for a manual trans, then the input is ignored.
Tim
Old Nov 3, 2000 | 04:34 PM
IRACE87's Avatar
Car: 1987 IROC-Z
So I won't have to worry about it I quess since I'm gonna have a custom prom for my 383
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
