bright lights
bright lights
How are the bright lights supposed to work.
When I turn the bright on the outside light change to brighter but the inside one never cut on. Aren't they supossed to?
The bright light do not shineas brightly as they should.
When you turn on the brights you should be activating the high beam element on the outside lamps and turning on the inside lamps. On the page below, you will find a modification that can help with the brightness of your lights too.
http://lighting.mbz.org/tech/how_to/relays/
