do i have to switch the wiring harnes if i replace the carburated 305 with a tpi 305?
Old Nov 8, 2000 | 10:20 AM
LIQUID RUBBER Z's Avatar
i am looking to drop a TPI 305 from a 87 iroc, to replace the carburated motor in my 86 Z-28,The motor switch should be simple,but do i have to switch the wiring harness with the tpi motor to? Is that enough of a pain to have some one do it, or is it simple for a home mechanic to do??Also is there anything else electrical i will have to purchase to do the motor swap??
thanx..
dustin
Old Nov 8, 2000 | 03:38 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Yes, you need to swap the engine harness for TPI. Remember it has injectors with wires going to them? Anyway, I doubt you will find someone to do it for you that really understands what he/she is getting into, so do it yourself. Also get the factory wiring diagram, I guarentee you will need it, I did.
There's also a whole lot of changes to be made besides the wiring and we havn't even touched on that. Don't forget about the fuel pump, fuel lines, computer, instrament panel wiring harness, fuse panel(more fuses), distrubitor and VATS system to name a few off of the top of my head.
Let me know if you would like the mod required to the instrument panel and fuse panel wiring harness. I made a drawing of the required changes.
I didn't worry about VATS because I used a 1986 engine harness.
John
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup.
http://64.176.105.239/octride.htm
Old Nov 9, 2000 | 03:43 PM
FormulaGod's Avatar
Holy cow. You have no friggin idea how much work you have ahead of you. ECM, setup itself, wires, chip, injectors, distributor, fuel rail, pump, afpr, oh boy. Good luck man..
"Ever notice how imports sound like weedwackers"
specialized
Jun 18, 2022 09:26 AM
Fast355
Dec 2, 2016 06:33 PM
Brcharrelson
Aug 26, 2015 07:47 PM
marcusaw
Aug 10, 2015 08:13 AM
drathaar907
Aug 10, 2015 07:44 AM
