Anybody w/ an '89 GM manual.
Old Nov 1, 2000 | 07:14 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I need the pinout for the PassKey Module.
i.e.:
A1 - Pnk/Blk,
A2 - etc...
I would assume that it would be the same as what my '92 manual says, but I want to make sure. TIA
Old Nov 2, 2000 | 12:26 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'll look in the morning for ya.
Old Nov 2, 2000 | 10:25 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
From the code 46 chart:
pnk/blk 439----A6 Ignition Feed(ECM)
dk blu 229----B6 VATs signal input(ECM)
This what ya needed?
[This message has been edited by 8Mike9 (edited November 02, 2000).]
Old Nov 7, 2000 | 05:48 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Actually, I need ALL of the pinouts.
Batt.
Ign.
ground
resistance high
resistance low
fuel enable input
etc...
If you live in Southeastern US, check us out!
South East Thirdgen
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
Old Nov 9, 2000 | 05:50 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Never mind. I figured it out. The '89 is the same as a '91. I just had a bad module. I installed PassKey into my '87 to avoid relying on custom proms. I saved about $200 by doing so ( I have connections), not to mention the added security (I have a '92 ECM that relys on the fuel enable signal, and I also did the start inhibit relay). Thanks anyway.
South East Thirdgen
Savannah, GA
'87 Trans Am-K&N, S/D TPI retrofit including functional PassKey, 22# injectors, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
gta892000
Aug 11, 2019 11:16 AM
Fireslash
Apr 11, 2016 06:43 PM
rubblerubble
Mar 13, 2016 06:57 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Ian Irvine
Sep 4, 2015 08:08 AM
