Engine swap wiring questions?
Old Nov 10, 2000 | 01:11 PM
Coolcars's Avatar
I want to swap an IROC Motor, trans, harness and computer into a 305 carbed TA I'm planning to use the IROC computer. How do I mate this to the under dash harness in the TA?
2E,87 Formula 350, 4 other Camaro's & 3 Firebirds to fix, Drive, or sell.
Old Nov 10, 2000 | 04:39 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Here is the missing wire under the dash that interface to the TPI engine harness.
This is assumeing that you are swapping from a carb to a MAF TPI.
http://www.geocities.com/millicanga/TpiWiring.jpg
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup, Dual IROC Fans.
http://www.sethirdgen.org/octride.htm
Old Nov 10, 2000 | 04:45 PM
Engine: 4.0L
Oh, and don't forget about the fuel pump, fuel lines, sensors and maybe VATS depending on the year engine wiring harness you get.
John
86 Camaro Sport
Old Nov 10, 2000 | 06:27 PM
Coolcars's Avatar
Yes I am going from a carb to MAF TPI setup, I have the complete motor and harness and computer so I should have all of the sensors. Correct? I know about the fuel lines and the fuel pump? The only thing that I don't have for a Firebird is the air intake being that it is different from the Camaro. Thanks for the reply, if you have any other information I'd appricate it. Thanks again
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
